Perform this procedure to activate or deactivate Energy Saver on the switch at any time. Energy Saver is deactivated by default.
Activating Energy Saver reduces the port speed to the minimum value supported by the switch and enables PoE power saving, even if PoE is globally disabled. Deactivating Energy Saver restores the previous configuration.
Before you can change any previously saved Energy Saver settings, you must disable Energy Saver globally.
  1. Enter Privileged EXEC mode:
    enable
  2. Activate or deactivate Energy Saver:
    energy-saver {activate | deactivate}
Switch:1> enable
Activate Energy Saver:
Switch:1# energy-saver activate
Deactivate Energy Saver:
Switch:1# energy-saver deactivate
The following table defines parameters for the energy-saver command.
Variable
Value
activate
Activates Energy Saver manually.
deactivate
Deactivates Energy Saver manually.
